Reducing PPT(Power point) Files
Discussion in 'Windows OS's' started by sandy8080, Jan 7, 2011.
  1. sandy8080
    sandy8080 Geek Trainee
    I have one PPT (Power point 2007) file which sized approximately 28 MB I want to send that file to Japan from India. My question is how to reduce the size of that file I have saved it to as Power point presentation but it reduce a bit say 28 MB to 24 MB. Is there is any way through which I can reduce the size of that PPT further.
    Hope I am able to explain the Question correctly
    Advance thanks for any Answer
  2. HardwareHunter
    HardwareHunter Geek Trainee
    You can convert this into a video. Or maybe check out this link to find ways on how to reduce a ppt.
  3. sandy8080
    Thanks Hunter. U R a real Hunter.
    Regards
  4. gibsswron
    gibsswron Geek Trainee
    First off, you'll need to do a little setup in PowerPoint. On the Tools menu, click Options, click the Save tab, and then clear the Allow fast saves check box. Doing this armament PowerPoint to abolish balance abstracts from your presentation book anniversary time you save. After you've turned off fast saves, save your presentation again under a new name. On the File menu, click Save As, type a name for the new version of your presentation in the File namebox, and then click OK.
