switching to linux need some help
for some reason i wasnt able to find the edit button
well guys i just wanted to update you a little more on my situation i was able to solve the cd rom
problem of opening the other drive
:x: silly me i had the cd-rom as slave and i had the other as master
the one i wanted to use as master was set up as slave
on windows that dint happen to me that i needed to use a specific drive because you know how on windows you can use both drives and just changed where you want the cd-rom to read from
well thats what i had solved so far
im researching on the other things and hard Drive not sure yet when im about to partition it it tells me something like is gonna move some folders and im not sure of like what it could do doing that
and the reason i think it dint' detcted it maybe because it was on ntfs format and i dont think mandriva supports ntfs because i dont see on the list of filesystems possible
