HI Anybody see a voltage problem here or any problem for that matter. Voltage Values: CPU Core 1.28 V +2.5 V 3.10 V +3.3 V 3.44 V +5 V 5.13 V +12 V 12.10 V +5 V Standby 5.03 V VBAT Battery 3.02 V Running a Ultra Xfinity 500w PS on a Dell 530 Desktop, core 2 duo 6550 320g HD and 3g Ram with Radeon X1950 Pro vid card Thanks
Where are you reading those values from? BIOS? Windows? ATX power supply standards allow for 5% fluctuation in either direction. Additionally, software readings aren't terribly accurate, as they don't measure the voltage at the source. Using a multimeter will give you more accurate results. Even if those are the real values, I'm not seeing an issue here.
Hi Those readings are from Everest Ultimate . Where would find the right multimeter and info on how to use it properly. Thank you
Here is how to test it. You can pick up a basic digital multimeter for $20 or less at Radio Shack. You can check the +12V and +5V straight from the power supply by measuring the voltage from a molex connector. The link goes over this info, but the black wires are ground, the red is +5V, and the yellow is +12V.
