Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
i dunno, i would just make a seperate partition for pagefile, 1536mb i think for 1gb of ram, so 3.72gb for pagefile with 2gb of ram, so make a new partition thats 4gb and have it for pagefile, thats only if you have the space, i dont know if you can afford to have 4gb for pagefile, i have a 2gb partition for pagefile, its on the same HDD as windows, but i sure do see an increase in speed.
Damn, just seen that pic you posted above showing task manager, is your computer running extreamly slow, i mean 100mb ram at startup :o, i think you should get 2GB of ram, but you also probs need to do a nice fresh and clean install of windows xp, how longhave you been using that instalation of windows xp for?
I thought XP performed slower with more than 1gb of RAM. That was the consensus a couple of years ago anyway.
How to make new pagefile? well do you know how to make a new partition, you need a program like Partition Magic 8, although most people will flame me for reccommending Partition Magic 8 as its preety crap :p, using somthing like paragon partition manager, i think thats what it's called, first you need to disable your pagefile on Dirve c:, to do this go to my computer, right click it and click properties, go to the advanced tab, then settings in the performance box, click on advanced, then in the virtual memory box at the bottom click change, click on the drive that says has the paging file, then click no paging file, then click set, and ok, you will then have to restart your computer, ok you seem to have alot of space, Try paragon partition manager, now have you got any free unpartitioned space on your HDD that you would normally use as backup? if so, right click on that unpartitioned space and then click on create, then in the box that says new size, change that number so that its round about 4GB, type the volume name as SWAP, then change the systen type to NTFS and press ok, dont click on surface test, at the top left click apply, now if you dont have any free unpartitioned space, make sure that on one of your partitions you have at least 4GB free space, click on the partiton and then click resize/move, then in free space after box, enter a sum thats around 4GB, click ok, on this free space you may have to format it, click on it and then click create and do the same steps as above for unpartitioned space except use all that partition you just made.
Right, once that partition is created, restart your computer, right click on my computer, click advanced, then settings in performance, then click on the advanced tab, then click change, select the partition names SWAP, click on custom size, set the initial and max size to about 3072mb, click set then click ok.
hope that helps, sorry if its confusing, i tryed my best :)
