Will not boot
Discussion in 'Power Supplies and UPS's' started by hbob51, Sep 23, 2008.
  1. hbob51
    hbob51 Geek Trainee
    This is a problem I have been having off and on for a while.
    I have a SR2173WM not original
    I have a the original 180gb Serial hard drive with Windows Vista
    I have installed 120gb with Suse 10.2
    and a 40gb with Windows XP
    Plus the original card reader
    1 DVD CD reader
    1 DVD/rw
    Plus I installed a ATI pci express video card.
    The problem at first was it would never boot to the PCI express card I updated the bio's and I set the MB to default to the PCI card and off and on it would boot to the PCI card others not.
    Well that problem seemed to fade away and another came up.
    that is the MB flashes the CD roms and you can see the hard drive light come on and that's it the monitor never powers up.
    At first you could turn it off by the power button and then re-power it back up and it would come on.
    Then after awhile that didn't work, so I disconnected all the drives including the Cd roms except I left the serial drive connected it did boot up I then reconnected the 120gb and the 40gb drives and it still came on I connected the DVD rw and to my surprise it still booted up for a short time again.
    And it started again this time the only way it seemed to boot if I injected the CD tray (I still have the one CD connected) and three hard drives, the card reader is disconnected still.
    By opening the tray it would boot to the bootloader screen which is where I go all the time as it lets me decide which system I want to run.
    Now once again it will not boot, I can tell when it will boot and when not, because if it's going to start the MB will flash my keyboard twice the first time when it flashes the CD rom and then when it starts the keyboard come on and stays on.
    Right now I have the one flash with the CD rom and thats it after a while the hard drive light goes out and then there is darkness.
    Has any one got a clue?
    I thought power supply but with only the three hard drives and the one CD oh and two fans on the case I am not sure.
    I have tried to disconnect everything again but it still boots to a black screen.
  2. Ghostman 1
    do you have onboard video /chipset card? If so hook up to it and see if it will boot. to me it sounds like a BAD video card....
  3. hbob51
    hbob51 Geek Trainee
    Yes, because of the problem I was having with my ATI PCI express card I have both cables connected to my led monitor
    The ATI card uses the hi def plug and the on board video uses a standard VGA cord which allows both to be connected at the same time.
    When the card would have problems the Nvidea on board chip would bring the monitor up any way, the difference could be seen because I have the updated drivers for the ATI card (better graphics).
    Thank you for your response.
  4. hbob51
    hbob51 Geek Trainee
    Oh and I am sorry yes I have thought perhaps the ATI card could be part of the problem because of the problems I have had getting it to be detected.
    And I think I'll pull that card and reconnect everything else
    IE the card reader and both CD drives and see what happens next.
    Yet I wonder why the keyboard does not have the power on light illuminated.
    And once the pc is running I never have problems.
    No warnings errors, no shutting down in fact it will stay running for several weeks as long as I never power it down.
