Hi,i have just switched on my computer and the first thing to happen was,a blue screen with the words saying CHCK DISK has been instructed,after the software ran,i got the message Multi(0)rdisk(0)partition(1)Windows\system 32\drivers,and it names all of the drivers on the computer/i have tried too boot from my last good configaration,and i have tried too boot in safe mode,but i keep getting the same message,the OS is XP,everything was ok the last time i used it,but now i cannot even boot the rig up,appreciate any help on this problem......Cheers WEG...................
if the error was Code: multi(0)[B]disk[/B](0)rdisk(0)partition(1)\windows\system32 i may have suggested you enter the recovery console & throw commands like bootcfg /rebuild or fixboot, however, i have to ask, what drivers are being a problem ? and has anything changed with the system between it working & it not working BTW: i may not be able to help you, as i haven't used XP for a while now, however, i will try
