SONY VAIO Shutting Down
Discussion in 'Mobile Technology' started by Ripper, Jun 21, 2006.
  1. Ripper
    Ripper Geek Trainee
    I think I am out of my league gents. This Memtest is a bit confusing for me. Anything else you can suggest?
  2. Matt555
    Matt555 iMod
  3. Karanislove
    Once again, I will ask you to paste your events from event viewer here and tell us if this thing happened after you install something in your computer. The more u tell us will make our work easier.
  4. Ripper
    Ripper Geek Trainee
    I will do some poking around here and see what I can find out. Do you think it may be a bad power supply.
  5. Ripper
    Ripper Geek Trainee
    I have not installed anything yet Karanislove, just running Motherboard Monitor. I am trying to uderstand Memtest but it is a bit over my head.
  6. Matt555
    Matt555 iMod
    Well I was referring to the PSU as I thought it was a Desktop, after finding out it's a laptop it's less likely.
  7. Karanislove
    A memory test will take so many hours to complete. Best time to this test is overnight, when you dont want any work to do on your Laptop. Please let me know what your event viewer says. What kind of error are in there.
  8. Ripper
    Ripper Geek Trainee
    Yes a laptop, any specs you need say the word and I will give you what you need :)
  9. Ripper
    Ripper Geek Trainee
    I was not able to get memtest loaded in.
  10. Big B
    If you run Memtest for 8 hours (ie. overnight) and it's not rebooting or giving you errors, it's time to look elsewhere. There's a timer that will show how long it's been running. If it's running overnight without rebooting...heck, even run it 24 hours if possible. Since Memtest doesn't run under any OS, it can help narrow down if this is a hardware problem or not.
  11. Karanislove
    Copy the memtest into a floppy drive. Set your first boot device to floppy from BIOS. Restart your computer
  12. Ripper
    Ripper Geek Trainee
    Getting Memtest is the problem, I can't seem to get it loaded in properly.
  13. Ripper
    Ripper Geek Trainee
    I tired to put it on the desktop, them I opened the exe. file and it ran this stuff it thing. Forgive my ignorance here :-(
  14. Karanislove
    It doesnt run under windows. You have to copy the file in a Floppy or a CD. Set your boot devices accordingly.
    To change the boot device..
    Power on your computer and press the delete or f2(Its written on the screen when you switch on your PC) button immediately. It will take you to the BIOS. Every computer has a different type of BIOS appearence. You have to fiddle around and find the Boot Devices. There set the first boot to floppy(if file is in floppy) or CD(if its in CD). Save and exit.
    Insert your floppy/Cd into your computer immediately. Things will start automatically.
    Hope it helps
  15. Ripper
    Ripper Geek Trainee
    Most certianly, I will try this when I have the time to fiddle with it. Thank you sir.
  16. Karanislove
    Let us know if you stuck somewhere.
  17. Ripper
    Ripper Geek Trainee
    I certianly will.
  18. thicko steve
    thicko steve Geek Trainee
    can i just say i had a sony laptop with this problem turned out to be a blaster worm pc shop sorten it out had to down load a patch great after ....steve
